Hello, I've searched the site, cuz I know Don answered a simliar question for some other person. Anyway here it is.<br /><br />I seem to be having a probem. Working on a 92 Alpha 1<br />gen 2 outdrive. Got the drive installed but there<br />seems to be a problem (I think) with the Forward/Reverse. The shifting<br />assembly on the right side is engaged, ditto for the drive coupler and<br />coupler slot. I know this is working because I can see it moving when the<br />remote contol is moved between F/R. Now, when I put it in Forward gear the prop<br />will spin clock wise (standing behind the boat), but will not spin<br />counterclockwise. In Reverse, the prop will do just the opposite? That's<br />not right is it? The lower shift cable works smoothly, and is not binding.<br />Also noticed the shift shaft coupler is not 100% straight ahead when you<br />put the boat in forward gear. Do I need to adjust then lower shift cable,<br />or what. Seems, if you put the boat in F the prop shouldn't turn clockwise,<br />but woud turn clockwise. Need a little help here. Thanks
