Re: Mercruiser Drive shaft spec
Dumpy, sounds like an interesting project, and it seams you have thought out things very well. There are a few points that I think I should bring up ( along the same lines as Tommays).<br />1) this is a boat, not a car, the engine and all associated parts are in a sealed bottom area, which is usually enclosed....very different than a car. 2) in most cases, the fuel tanks are in the same area as the engine.....most cars have the fuel tank at the opposite end of the vehicle. 3)One of the biggest hazards in a boat, believe it or not is fire. If you combine all of the above, here are some things to keep in mind.<br />Gas is lighter than water, but gas vapors are heavier than air....not a problem in an open bottom car engine area....BIG PROBLEM in a sealed bottom boat engine room...the gas vapors will stay there. Everything in a production boat is ignition proof or explosion proof.....if it can possibly make a spark, or generate exteme heat, it is totally sealed from the enviroment that it is operating in. The short list would be: starters, alternators, relays or contactors/solenoids, ignition components, circuit breakers, fuse holders....etc. Exhaust components for a marine engine cannot exceed 200 degrees fairenhight, car exhaust components can reach a few times that....they must be wet or water cooled. The list goes on....we all want you and everyone boating around you to be safe. I admire what you are doing....just remember to think about boating safety....it's different than road safety.
