mercruiser elec question
vdubyah73
which wire brings power to the dash,purple or red-purple? Maybe another wire all together? 1993 mercruiser 5.0 lxeng #od707326 thunderbolt IV ign.Nothing works at the dash,starter doesn't click, tilt/trim doesn't work,gauges don't move when key is on. There's a bus bar with power,if I jump that to switch tilt/trim works but no starter.So assuming correct color code, which wire does it. My Clymer is not very clear after the engine plug connector.<br />Thanks Bill
Ralph 123
Re: mercruiser elec question
What's up Cape Cod!<br /><br />Purple - it feeds the Ignition Switch to Coil & Electrical Instruments and the Distribution Panel Electrical Instruments<br /><br />Here's the color codes and functions:<br /><br /> http://www.ancorproducts.com/Technical_information/Marine_Color_Code.php <br /><br />Check the "I" terminal on your key switch and any kill switch you may have...<br /><br />Now, where are the Striper running down there right now?
Fishermark
I would suspect a bad / corroded connection at the engine plug. You may need to even splice into the harness and bypass the wire at the plug.
