hey guys I am having a hard time aligning my engine (1991 3 L mercruiser) I took the engine out of another boat and installed it in my new boat (1989 invader) along with a new transom, I have the alignment bar but it really seems like the rear engine mount has to be shimed up, is there a chance that when I drilled my new bolt holes into my transom i was off a bit? because it looks like the holes in the inner transom plate are sloted. the only way i can get the alignment bar sliding in and out somewhat freely is if I drop the front engine mount to its lowest position then when i grease the alignment bar and slide it in and out of the coupler i got heavy spline marks on the top of the bar and light on the bottom of the alignment bar. I have just installed a new gimbal bearing also. thanks guys I need to get this aligned asap because I am renting the alignment tool thanks
