I recently purchased a 1996 bayliner 1950 capri which may have a cracked block (disclosed to me prior to my puchase)The engine is a 3.0 mercruiser 4 cly with an alpha 1 stern drive. The problem with the engine occurred when the prev. owner did not winterize the boat, and a freeze plug blew out. To make matters worse they did not know this, and took the boat out last july and the engine overheated and actually caught fire, (only burned the exhaust manifold area) I intend to pull the engine and check the block, etc.. but my question in this forum is what can I replace it with, and hook up to the existing alpha 1 stern drive? I can obiviously replace the engine with a drop-in 4 cly mercruiser, or replace the block and overhaul, but would a 6 cly merc, and or even a 8 cly merc work with the existing stern drive? If yes what specifically would I have to obtain to mount the engine and hook up to the stern drive. <br /><br />I would appreciate any ideas. Thanks
