Friscoboater
- Jul 3, 2009
- 3,095
My boat has the exhaust tube instead of the bellows. My question is can I run without that tube in place to keep the gases from going through my leg?
How come you don't want exhaust going out the leg?
I was afraid to ask that one, skargo!![]()
Hmmm.... is this done on boats? Open exhaust, thru-hull into water?
If the pressure is high enough at idle, the engine shouldn't stall (thinking out loud). On a thru prop set up, I would think it's designed to flow fast enough with enough pressure to prevent a stall.
On trucks, it's common to see tips turned sideways so that they aren't submerged when launching/retrieving down a boat ramp (possibly stalling the truck). That makes me wonder about a regular exhaust tip being submerged.
I think I read in you other post you had a 305......
My suggestion would be to replace the 305 with a 350 with Vortec heads and run the exhaust tube.......Would probably be easies than the thru hull exhaust and you will get more performance out of it.
