farmer9009
- Aug 23, 2009
- 69
Is there a space on a Mercruiser front Motor Mount between the metal washer and the bracket assembly that holds the front motor mount.
I know there is a fiber washer and a spacer between this portion of the mount. When assembled as the diagram shows I end up with a gap. I could imagine this allows for the motor to move under torque on the mount, I just wanted to be sure a gap is supposed to be there. Attached is a photo with an arrow to clarify the area I am asking about.
Thanks
Edit: to clarify the metal washer is not tight against the fiber washer. The fiber washer just sits on top of the assembly with no pressure on it.
Thanks
