Mercruiser fuel pump tensioner help
samm835
So I have a 96 mercruiser, I had to put a new v-drive belt on my fuel pump. I got everything on but I can't keep tension on it. Is there a trick to tighten this freakin bolt for the tensioner? I'm about ready to put a bullet in this motor lol!
alldodge
Its a 96 Merc, WHAT????
Serial numbers work best
samm835
Yup....looks like I got a head of myself and left out some important information. You can't read my mind on what motor I have? It's a 96 mercruiser 7.4 with carb. I looked for the serial numbers today but I couldn't locate. Here is a picture of what it looks like behind the pulley tensioner.....I've never seen something like this, how in the hell is it supposed to tighten and stay tight?
Bt Doctur
loosen the 5/8ths nut a bit, using a 5/16ths socket on the hex shaft rotate to tighten belt , hold in position, tighten nut with a 5/8ths open end
alldodge
That is not an issue, take a 5/8 boxed end wrench an loosen the nut on the other side. Take a 5/16 boxed end wrench and place on the small end of the bolt extending out inside the larger nut. Turn the 5/16 until tension os correct, then hold the wrench still and tighten the 5/8 wrench
Eazy Peezy
