jmccall001
- Feb 23, 2005
- 103
Thanks for the advice, 82 se ray, 260hp mercruiser, 888 drive - still having hesitation when rapid acceleration ease it in and seems to do better, we have replaced fuel pump, cleaned vents, new points, plugs, timing is perfect, distributor advances to abt 82 degrees at 3500, new fuel filters, replaced carb, compression is ok per mechanic. coil replaced, could the dashpot be a problem, the rebuilt carb appears to have an older dashpot on it.
