Hello, I have a 1988 31 Pacemaker sportfisherman with twin Mercruiser 5.7 bluewaters. I have been having problems with low power (RPMs) in the port engine at first I suspected it was starving for fuel which I have ruled out by replacing all filters (yes the one in the carb also) and testing fuel pressure which is 9lbs at wide open throttle. It was during this test that I discovered that when the engine hatch is open the engine picks up 500 or more RPMs as soon as you close it it drops off again. I have checked the side air vents for blockage. I am not sure what to check next
