Mercruiser LH vs RH
105mich
So if I am replacing a LH engine with a RH engine...do I need to change lower units as well because it was a LH?
Ayuh,..... Welcome Aboard,..... Whatcha workin' on,..?? What drive,..??
Why would ya be usin' a RH motor,..?? they've been obsolete since the '70s,....
105mich
Oh i see where I was confused, the lower unit controls rotation then?
Bt Doctur
There never was a "right hand engine" used in a outdrive application. Engine rotation is viewed from the flywheel left hand, CCW
that would be clockwise looking at the front of the motor
JoLin
Yes. I have counter-rotating drives on my boat. Engines are the same and both rotate counter-clockwise (viewed from the flywheel looking forward). The drives make the difference.
Bt Doctur
And when removing the drive the standard one RH prop goes in fwd. the counter rotating drive LH prop goes in rev
