Mercruiser Low Speed Idle Adjustment
HellRaZoR004
I have a 1999 Mercruiser 5.7L EFI engine that runs great but I think the low speed idle is a little high (800rpm).
I would like to dial down it down to what I've read on the internet should be around 650, but would rather do it myself and learn something along the way than having the shop do it for me.
That being said, can anyone give me some help on how to do this? I do not have a service manual for the engine (Serial Number: 0L095724).
Thanks,
Rob
Re: Mercruiser Low Speed Idle Adjustment
Thanks,
Rob
Ayuh,... Welcome Aboard,... It's done with a 'puter,... it's Not a mechanical adjustment...
Don S
There is no idle speed adjustment, that is done by the ECM and the IAC to control it. What can happen is the throttle cable wears and does not allow the linkage to go back to idle. Disconnect the throttle cable from the throttle body and see if the engine will idle down.
HellRaZoR004
Thank you! These engines are getting harder and harder to work on yourself.
I'll go ahead and disconnect the throttle cable and see what happens. If it does go down what are my options?
Don S
Adjust the cable so it lightly pushes the linkage to the idle position.
