Hello to everyone,
This year i bought the Mercruiser MAG 350 MPI in order to change my old 5.7 carb merc.
Now my problem is that i wan't to keep my Alpha one gen II sterndrive but the new motor has an ECM programmed for Bravo drives and its not recognizing the signal from shift interrupter .
This swap has been discussed in this thread http://forums.iboats.com/forum/engi...pi-bravo-to-alpha-config-swap?_=1467532423434 but now its closed so i couldn't post there.
I had came up with an idea but i need some help on order to make it work.
I have an electrical engineering background so i made a board with a relay which works as follows:
When it detects a change from the shift interrupt switch it will turn off the engine for some milliseconds.
Now, which i the best way to cut off the engine? The ideal situation would be to have some "kill switch" cable from the harness and when i grounded it the motor will cut off.
Thanks in advance,
Thanos
Thanks in advance,
Thanos
