Subscribing in . . .
There is another recent thread about a 5.0 MPI No start. Is this the same engine or is there a Merc 5.0 MPI pandemic in the making :noidea:
This is the re-build on the 5.0 MPI :thumb:
"loud bang" as in a backfire?
If you open the throttle before cranking, the engine starts and runs properly? (or does it not run well even after starting?) How much open does it need/like in order to start?
I assume you have checked, doubled checked, and re-checked all of the basics . . . #1 TDC, spark plug wiring, timing is in the ball-park?
[/QUOTE
Yes, like a backfire. The engine does run fine for a bit with the throttle open.I's say it keep it open about 10 degree, anymore than that it stalls. I did check TDC, spark plug and timing. Although I am not sure if my timing was based at TDC at compression or exhaust. I failed to check TDC at compression stroke. With the engine assembly, I am struggling to rotate the engine to find TDC compression.
