Mercruiser MCM 140 - Fuel pump sight glass tubing
Kdreese89
Does anyone know what the I/D and O/D of the Tygon Tubing used on the Mercruiser MCM 140 (1985) that runs from the Carb back to the fuel pump if the diaphragm ruptures? The one on the engine I just bought has become extremely rigid and detached from the fuel pump and I do not trust it for measuring since it is wrapped so badly.
Thanks
I couldn't find the tubing in the auto store so I got it from my Mercruiser dealer. Don't run the boat without that tube. If the fuel pump leaks without the tube you'll have a gasoline leak.
Ayuh,.... I believe it's 1/4", or 5/16" tygon tubin',...
Lowes and home depot have clear tubing in the lawnmower repair section
Kdreese89
Well the LowCheapo Depot special did not work. They only had up to 1/4 O/D Everbilt "fuel" tubing. So now I need to figure out the actual size and order the line.
