Re: Mercruiser Motor Timing
base timing on the distributor. not sure how your motor is set up, however my guess is about the range of 6-10 degrees advance at 650 RPM. your total advance will depend on the engine, the compression ratio, the cam timing, drive gear ratio, hull shape and weight, and prop. most distributors have an advance of 18-24 degrees with the majority being between 20 and 22 degrees.
so lets say your advance is 20 degrees, and your base timing is 10 degrees. you have total timing of 30 degrees.
the motor itself doesnt know its in a boat. it just knows its a motor. so if its installed in a truck, its a truck motor. if its installed in a boat its a boat motor, if its installed in a car its a car motor. the only caveat is that on a boat motor, all the stuff bolted to it must be marine certified.
