mercruiser omc morse control box
newtoboat101
1988 Thomson 240 ,have mercruiser omc morse shifter control box with 5 wire 2 switch need to find switches and cable for trim and tilt switches ,do they still make or is there a replacement part for this or what does everybody do if switches do not work can you replace switches and put next to shifter,like my trim tab switches ,I have all parts( switches and cable wire),one switch has fallen apart and other switch has loose connections any suggestions thanx kent
Ayuh,...... What motor, 'n drive,..?? Merc, 'n OMC are 2 different manufacturers,.....
OMC is outa business,.....
Morse is also gone, bought up or broke up by somebody else,.......
I delete the trim limit, 'n just power the trim with a single switch,.....
On my last barge, it looked like a signal light switch on the left side of the helm, push up, the drive goes up, pull back the drive goes down,....
