Mercruiser outdrive gear ratios
jason7113
Hello, I am replacing an old worn out Mercuiser Bravo 3 outdrive. The old drive gear ratio is 2.43:1 which is no longer available. I can replace it with a 2.20:1. Will this drive work? Will I have to re-pitch or buy different props? Or is it not possible for this drive to work for the application.
Ayuh,..... Welcome Aboard,..... What rpms were you seein' at Wot,..??
That's a very small difference,....
Where the rpms come in will determine whether different props are necessary,....
tpenfield
2.43 . . . that's a new one to me. :unsure: Worst case, you might have to go down one step in the pitch, since the ratio is close to the original.
wasnt the 2.43:1 only behind the V6?
achris
More fish than mountain goat
Nope, still available new.
achris
I think Merc drop that 'this drive ratio for that engine' thing a few years ago. It's now up to the dealer to select the most suitable ratio for the customer...
Chris......
