Mercruiser outdrive lower section won't separate!
model14
I am trying to remove the lower section on my 1988 Mercruiser Alpha 2.5L (1988 Thunder Craft regency 162 restoration). This particular model appears to have only 4 total bolts holding the lower to the upper section. One under the trim tab zinc, one on the very forward end center, and one on each side forward. I had expected to find 2 bolts on each side based on my repair manual and what I have reviewed on YouTube, but I can't find any others than the 4 I found. In any event, the two sections won't separate. I have "massaged" the lower section with a block of wood and hammer as much as I dare, but nothing is moving. I am afraid I am missing a bolt somewhere but I sure can't find it. Any advice on how to proceed will be greatly appreciated.
Thanks,
Richard.
FreeBeeTony
Re: Mercruiser outdrive lower section won't separate!
There should be 2 more under the cavitation plate.
They may be covered with growth if the boat is kept in the water......barnacles, etc.............
Ayuh,... Agreed,... Find the other 2 nuts, 'n it oughta come off,...
model14
Okay, gotta find them suckers. I'll let you know where they be :joyous:
FreeBeeTony
Not hard............just clean the crud away..............5/8" socket.
model14
Found the nuts and the lower unit dropped right out. Thanks.
model14
'O' ring on lower driveshaft?
Just pulled the lower gear case on my 1988 Alpha one. Drive shaft has an O ring groove right below the splines, but no O ring is present. Repair manual says that replacement shafts from Mercury don't have an O ring groove. Am I okay leaving it out? If it isn't necessary i don't want to put one in.
Thanks,
Richard
thumpar
Leave it out. It can cause more problems.
