I just rebuilt my outdrive on my 1978 merc 140 4 cyl. I did the water pump and all the seals, cleaned and lubed it. When re-attaching it, should the cavity where the drive shaft connects be filled with grease or do you just spread grease on the shaft itself? I filled all the zirc fittings with grease and noticed the one on top of the outdrive was the only one that did not seem to fill until grease came out. What does this supply? Another area that has me confused is the hydrolics for the trim. Where do you add fluid? The pressure on mine seems slower now than it has been in years past.<br />Thanks
