Kauaiboy206
- Mar 9, 2017
- 133
I've got a 1979 sun runner with a mercruiser mcm 470 per tag, but the serial numbers on the stickers are both too worn to read on engine & outdrive. My dilemma is that the"port hole" not sure if it's the proper term is corroded causing water to go in bellows and gimbal even with a new seal. I was wondering if I can swap out the bell housing from a Mercruiser alpha 1? I can get my hands on a full transom/gimbal with trim "forks" assembly without upper/lower for a reasonable price locally. The alpha 1 assembly also have the trim sensor & limit attached which I also need to replace on my pre-alpha due to wires fraying and exposing the wires. Thanks in advance "new to boating & inherited the 79' sun runner which is made here in Northwest, WA
