Mercruiser Points OMC electronic
savetexomabeaches
I have a 1991 Mercruiser 4 cylinder that has points. My buddy bought a 1993 OMC 4 cylinder that has an electronic ignition. I was curious if I could use his distributor from his OMC and stick it straight into my mercruiser. If so, does anyone know the process? Thank you
savetexomabeaches
Will take some pics and see later, right now dealing with tornadoes here in north texas. it looks like the same type of distributor, but also has some mechanical rectangle thing with wires leading into it attached.
Ayuh,... Take a Close look, it'll have a number, 'n probably a name, on it somewhere,....
savetexomabeaches
Ok, so the Distributor is: Delco j1171 1103782 1k16 I believe the coil is 1h06 1115491 and a mystery part is : 987566 4 cyl chev 5 kq I have photos, but for some reason, I click upload, and nothing loads
alldodge
The distributer is the Delco EST, so you got the good one there and it will fit
fetch
If this is on the transom it looks like the trim on the OMC
fetch
savetexomabeaches
Thanks. Yes, found out via wiring diagrams for the OMC, that the mystery part is the ESA (shift module).
