Mercruiser power assist steering
marsharc
I have a Mercruiser 454 stern drive with "Power Assisted Steering" on a 25ft Pursuit. The problem I have is that I want to put a 4 stroke trolling motor on it with a rod hooking it to the outdrive but you can't steer unless the engine is running. Has anyone ever replaced this with a regular hydraulic steering system?
Re: Mercruiser power assist steering
Ayuh,... It's reasonably easily done... Go for it...
Bt Doctur
Even without the power assist you should still be able to turn the steering wheel .
May want to inspect your complete steering system for binding.
achris
More fish than mountain goat
As the Doc said, you should be able to steer without the engine running.
