MerCruiser Power Problem
tsal
Hi all,<br /><br />I have a 1989 4.3 Alpha 1 Mercruiser. It starts OK, and idles OK, but after about 30 minutes, the high speed RPM drops to about 2,500. I can idle down, but when I try to throttle up it coughs and pops out of the exhaust. If I remain at idle for 20 minutes or so, or shut it down for the same amount of time, then my top end is back. Any ideas would be appreciated - I think it's fuel related, my brother feels it is electrical...
BIGALF
Re: MerCruiser Power Problem
I SEE YOU NEVER GOT AN ANSWER TO THIS PROBLEM. iF YOU GOT IT FIXED i SHURE WOULD LIKE TO KNOW WHAT IT WAS. i SEEM TO BE GETTING THE SAME PROBLEM ON MY 240 SEARAY dECKBOAT WITH THE MERCRUISER EFI.
I THINK I NEED TO CHANGE THE SPARK PLUGS AND KEEP ADDING FUEL INJECTOR CLEANERS
Don S
Try this test procedure, sounds like you may have a fuel dilivery problem.
http://www.iboats.com/bbboard/bbBoard.cgi?a=viewthread;fid=24;gtid=1107009
BIGALF, please turn off your cap locks, it's hard to read, and in forums it's considered yelling, and I know you aren't yelling at us .............. are you :%
You should also start your own thread, you should include all of YOUR information, including year, make, model number, and serial number if possible of your engine.
had a ford mustang with a 302 that did the same thing. cold it ran fine. when it was warmed up, it would loose power. if it set or idled for a while, it would run ok for a whilke again before loosing power.
it also used to backfire through the exhaust system when i was giving it gas.
turned out i had 4 burnt exhaust valves.
do a compression check.
