Mercruiser Power Steering Hose Part MER32-806222-16
cheswest
Is there an automobile version of this or am I "fitting limited"? - looking at 200 bucks + up here in Canada for the Merc / Goodyear. Cheers
alldodge
Need to find a hydraulic shop to make up some hoses using metric fittings. The latest large hose is 14mm x 1.25 inverted thread
Look up Mercruiser hydraulic lines and you can find Aeroquip fittings. While I've done some research just have not done enough yet. Take your line to a store that has metric and SAE nuts an bolts. Try to find a nut that your line will screw into, that is the thread size and diameter
Bt Doctur
And if its the low pressure return you wont have to worry about the pressure
