artificialreef
- Feb 21, 2009
- 504
Hello again friends. I have actually gotten both motors running on my resto of the basketcase i purchased, and am moving on to the outdrives. One drive's tilt/trim was frozen so i yanked the pump out and unfroze it with a new motor and some flushing and pump parts. All my rams have the lockring that is supposed to hold the scraper on the ram shaft dangeling. Anyhow the cheap sob i am i decided to rebuild my rams. First off. My spanner wrench would not take the cap off. I ended up using a torch and a pipewrench.
long story short, I read the disassembly and reassembly of the pdf file and I counted the o-rings and seals and dont think i have to disassemble the spring assembly. I dont see whats replaceable there. Anyone rebuild a trim ram on here before.
Question: Is it necessary to disasseble the spring and check ball assembly when re-fabbing this ram?
Its an R-drive with the supply and return external. 2 lines.
