After fogging my engine, I pulled the plugs to put fogging fluid in each cylinder. When I pulled the spark plugs, I noticed that the tips were oily. That was expected. What I didnt expect was what I thought was excessive carbon deposits, like the engine was running really rich. <br /><br />My power plant is a 2004 5.0L carbureted Mercruiser, Alpha 1. The engine has about 65 hours. When I changed the oil at 20 hours, I put in 25W-40 Mercruiser oil (dino). I used 93-octane fuel all season because thats the only grade fuel available at my local Marinas. The engine is raw water cooled. Most of the time I put on the engine was under heavy load (skiing and tubing). Any thoughts on how I should correct the problem?
