Originally boat was an '89 Mercruiser Chev 350/Alpha 1. Blew motor and picked up a low miles 305 to get my by for a season or two. Swapped my marine parts over to it, water pump, manifolds, distributor, brass plugs, etc. Engine ran great in the car ('87 Firebird), good power, no overheating (180-190), ran well. It is a GM reman with about 20,000 miles.
Problem in the boat now is that temp just keeps creeping up. I shut it down around 200*. Tried replacing thermostat, no dice. Impeller is new, only 6 hours or so on it with the old motor, no dry starts. Decent water flow out of exhaust ports on gimbal housing.
Thermostat housing has 6 ports. Inlet from drive/hose is cool. Outlet to water pump (engine mounted) is hot, the two ports to the manifolds are hot, and the ports to therisers are cool. Risers are cool to the touch (can leave my hand on them plenty long, warm but not hot). Back side of thermostat housing is hot, can only hold hand on it for a couple seconds.
I believe thermostat is opening because the high ports above thermostat (to manifolds) are hot, and I get same conditions with old thermostat and new thermostat (140*).
Set timing at 10* initial, tried advancing it a bit and no change in temp. Not sure how I should proceed. Any ideas?
