Mercruiser serial numbers
1850ssi
HI..trying to find the serial number on a 4.3 mercruiser. I found 4.3LG 14098000 on top backend of the motor behind the head. I called the parts house and this number is not the serial number. Where do i find the serial number? Thanks...also,its a 2000 chaparral with a reman motor that was put in 2007.
Don S
Re: Mercruiser serial numbers
Unless the "Reman motor" came from Mercruiser, it doesn't have a Merc SN, and knowone here knows what was installed, you have the boat and the engine, so you have to tell us what you have.
1850ssi
It is a 4.3 v6,where do i find the serial number on a reman motor?
Don S
Depends on who did the reman.
Ayuh,... If you're Lucky,..
It'll be on a little aluminum tag riveted to the block, just above,+ possibly forward of the Starter....
Just what is it you're trying to Buy for parts,..??
