jmccall001
- Feb 23, 2005
- 103
my mercruiser 260 started stalling when put under load. At idle in slip no problems, under load at 2000 rpm for about 30 min, it runs smooth as silk, then sputters, threatens to stall then stalls and will not start. Put it up past 2800 rpm, it begains to sputter and then stalls and will not run. I've replaced fuel filters, (both) the fuel pump- slightly weak, checked compression, timing and replaced the carb. The only other "symptom" is that fuel must be added very slowly to the tank from the pump. If y ou do not periodically stop, the fuel will bubble out of the filler.<br /><br />I need help
