It is time to get the boat out on the water again.
Last fall I had some issues with shifting on my boat. it would go into reverse but not forward. after adjusting the cable it will go into forward and not reverse. Anyways, after measuring slop, and adjusting the cables, and brass barrels and everything else the problem is still there. However I think I might have found the issue but I want to make sure.
At the end of the shift cable in the bell house there is the "Shift Slide". This connects to the "shift Arm" which moves the shafts. (I know you all know this already, but I just am tying to be as clear as possible). Anyways, when I grip the shift slide with my thumb and index finger, I and slide the shift slide backwards and forwards, there appears to be "loose" movement as if it is not fully secured onto the cable or something. The movement is not moving the cable itself at all, it appears as though the shift slide is gliding back and forth about 1/8" give or take.
At the same time I noticed that the Shift arm has a pin with a black poly bushing or something that rolls with the shift slide in the groove. After looking at the bushing, it has warn, high and low spots from what looks like "scrapes or grind marks". Also worth noting is the shift slide has wear marks in the grooves where the shift arms contacts the shift slide, like it is wearing the metal away a little near the point tips.
Could this be the cause of my shift problem? When I adjust the cable, it goes into drive it will not reach reverse. However it appears it is just shy of engaging reverse. I am wondering if this slop in the shift slide, with the warn down bushing, and slide edges could be the excess play that is screwing things up?
a local shop in town has a new shift slide I can go get. Can I replace the shift slide without pulling the shift cable from the boat?
