Mercruiser tilt trim
Fish mojo
My reservoir for my mercruiser hydraulics has milky oil. I changed it once with a transfer pump and put in clean ATF, thinking it might have got moisture over winter. Well, its milky again. I think the seals on the rams are leaking.<br />What does it take to re-seal the rams?? is this a DIY job?
Danny_Ocean
Re: Mercruiser tilt trim
is this a DIY job?
Depends. Yes, the rams are rebuildable, and rebuild kits are available, however you may need some special tools/skills to do it yourself.<br /><br />Also, if the rams are old and looking ragged/corroded, I would try to find a new(er) set. Recently, just missed (by $2.00) a BRAND NEW set of TRS rams on E-Bay for $225.00!!!<br /><br />D. Ocean<br />Pompano Beach, FLA
Danny's Right.......<br />You can find used rams at ebay, Cheaper than the rebuild Kits.......... ;)
