Submariner1
- Oct 25, 2004
- 4
I am trying to set up the timing on my 1999 3.0L Mercruiser (GM). I have a Clymer manual and it states <br /><br />"Disconnect the shift interrupt switch from the engin harness, then connect the engine harness wires together. Do not allow the shift interrup swich wires to contact each other."<br /><br />Does this mean connect the wires coming from the engine wiring harness together. I have tried this and the engine almost stalls and I then have no indication of timing marks when I use the timing gun.<br /><br />My timing can't be that far out?? What I am I doing wrong.<br /><br />I have also connected the jumper wires to each of the white leads extending from the distributor as indicated in the manual.<br /><br />Help please.
