Mercruiser TR or 215?
Status
Not open for further replies.
Sea Rover
I have a 1970 Sea Rover with twin 302 mercruiser engines. I thought I had "TR" outdrives due to removable rear cover and 1 7/16 prop nut. However, I have Mercruiser 215e shift actuators. Is this a TR outdrive with a mercruiser transmission or a 215 outdrive? I'm looking for service info as these units have been laid up for 10 years.
Re: Mercruiser TR or 215?
Ayuh,... Welcome Aboard,....
Post up some Pictures, 'n We'll see if We can tell just What you've got....
ziggy
looking at a mercruiser engine drive model year reference chart. it appears that in '70 and '71 a ford 302 was mated to a 215H drive... this appears to be the only two years that a 215H was used for anything. in '71 the 302 could have been a 215E also.
Sea Rover
Thanks for the reply! Took me awhile to get the pics right size. The shift actuators are definitely 215E's, but could have been changed. The outdrive looks to be a TR. Info I got from mercstuff.com shows them available from 1970 thru 1990.
Dpampel
The drives are different. The 215E was used from 70 to 72, the TR didn't come out until 77.
Here is the service manual that covers the 215E, http://www.4shared.com/document/ozc1_97A/Service_Manual_01.html
and here is for the TR http://www.4shared.com/document/5NMHchNR/Service_Manual_05.html
Biggest problem you are going to have with them is parts. Most are NLA for those drives.
Could you repost the link to the 215E service manual. We are having trouble getting ours to shift to reverse.
Status
