Mercruiser Trim Cylinder Question
25thmustang
I just picked up a project boat and the trim isn't working. Got the pump/motor all cleaned up and bench tested and now it's on to the cylinders. As luck would have it both cylinders were "locked up" in the trailer position. I got one apart and free to rebuild, having trouble with the other.
I'm most likely buying new however am finding some cheap used cylinders (I may use to test the system). Are all alpha 1 gen 1 cylinders the same (I have a 5.7, would a 3.7 cylinder work?)?
Thanks!
xltier
there are diffences. i dont think its engine related but transom assembly. difference in length of cylinder
25thmustang
I wonder if there is a way to determine compatible models? I have seen quite a few used options but no guarantee they will work.
Ayuh,...... There are several varieties, but they're very interchangeable,.....
Especially if ya get the pair of cylinders, 'n mounting pins,.....
25thmustang
Would most/all Alpha 1 (gen 1) cylinders work? There are lots of used options out there but I would hate to buy something I can't use.
