johnsland8
- Jul 12, 2008
- 56
I have a Mercruiser 165 in a 1988 Bluewater. I'm not sure of the drive year, it's not the original drive.
I rebuilt the trim cylinders, installed them, and bled the system. The pump will run in both directions and there is plenty of fluid/oil in the reservoir.
The cylinders will extend just fine but they will not retract. If I relieve the pressure by disconnecting the forward return hose on one side, they will retract just fine. It acts as if the fluid is not being allowed to return to the reservoir. In the manual it appears the return line is a straight shot from the cylinders back into the reservoir.
I was just curious if anyone could provide the most likely cause of the problem?
