mercruiser trim goes down but don't up
Leandro
i just bought the boat, and i replace the oil on the pump b'cause it was bad ( to white or something like that) but it was working before up and down, but not now, is just going down and when i push up i don't here nothing any noise or something when i push up.
and don't have any clue whe i go first
thanks
solar7647
Re: mercruiser trim goes down but don't up
There should be two solenoids, one for up and on for down. It sounds like there is an issue with one. Perhaps a loose wire or it is bad.
A easy way to see if one is bad is switch the two and see if the up works and the down stops working. Should be easy to do.
They look like this...or similar to this
ken_23434
Try using the trailer button. There might be a problem with the trim limit switch alignment. The trailer button bypasses that limit switch.
rocket1968
bring out the voltohm meter and start testing. I am betting person it is either the connection at the solinoid or the solinoid itself.
Leandro
thanks for the quick reply!!!! i check the solenoids and both are working, the problem is i push down and never stop by it self and when i push up, run for a second and suddenly stops.If i push down again it happend the same thing .
i mess up something when i replace the oil?? . i just unscrew the pump(all together with the reservoir) upside down it , to drain the oil and put a new oil on it.
By the way my boat it's a 1994 glastron volvo mercruiser 3.0? i believe it i do not havre any manual or paper work.
thanks again
solar7647
Well you could have messed up some wires when you tipped it. Have checked all the connections to the pump?
cooter2506
Its either Volvo or Mercruiser not both. Got to know which one so we can hep you.
Leandro
could be the engine volvo and the out drive mercruiser?
sorry but i'm an inexpert on boats , everiwhere said mercruiser but the previos owner tolde vovo?.
alien4fish
can you post up some pictures of what you have please?:D then we can better help you ;)
Leandro
Hi, I?m back I was in Tulsa, for a few days (doing accounting on tax deadline make my life hard).
I put it back everything together today and, it is working now, I do not change nothing goes up with the trailer switch and down with the other.
I go to take some pics today to show it what I have.
I?m trying to put this boat in a good shape. For this summer and I have to learn a lot.
Other than that I have to learn how to set the right level of the trim using the boat to get the best performance, any suggestion?
Thanks a lot
Mirage502
I am having the same difficulty, in addition to that my trim guage is pegged to the bow up position as soon as the ignition is turned on. I have found some dandy ideas as well as a full PDF file on the trim motor. Nowhere in that did I see any talk on the guage. Any ideas??
bomar76
It's becuase the trim motor has nothing at all to do with the trim gauge, which by the way is the most useless gauge installed on boats.
The trim gauge and trim stop are controlled by the two round senders on each side of your drive.
They are a major PITA to replace.
Mirage502
If I am hearing you, fix the trim problem and put tape over the guage??
Leandro
i do not care about the gauge , my pump never stop either , i just wondering withch is go to be the right possition for the prop to got the best performance.
so how whe change those limits?
i wouldt take a picture tomorrow of those two round sensors to post and u can telle me if is something wreong with it.
sorry about my ignorace but what is that PITA?
Don S
First, which do you have, a Volvo or Mercuriser it makes a big difference.
You seem to be missing the most obvious tool in this whole process. The OEM service manual. If you narrow down what you have, there are OEM manuals up in the Adults Only sticky that you can download for free, and would make this job a simple problem to troubleshoot.
Leandro
yes i do not have anY PAPER WORK about this boat i put the pics here, to figure out withc one is.
thanks.
aaahh!!!!!, that P .i .t.a, that thing u got whe u carry a ring on u'r left hand?jeje
Ayuh,... Your links are Dead Ends,... Files have been moved...
Don S
He has a Mercruiser 3.0L engine with a Mercruiser Alpha I Gen II outdrive.
The pictures are usable in his other post where he is looking for a manual.
Now that he has links to the manuals, he can download them, look at section 1C in manual #14 and be able to figure out what the problem is.
