Re: Mercruiser trim problem
Seven two, I've got an idea, but you most likely don't want an IA's view on this......<br /> If your hoses are correct, you have a hell of an airlock which will require loosening the hydr. fitting at the fwd portion of cyl. Just crack it enough to hear air, or see fluid.<br />If you can get it down (by cracking fittings and applying weight to unit) you can pull nuts from thru-bolt at rear and remove that end of the cylinders....careful with the rubber bushings.<br />With unit fully retracted, refill res. and run trim out slightly while someone watches cylinders. If they both move, go all the way out, and hit the down button....if they go down, continue the cycle 5 or 6 times and this will usually work the air into the res. If They DON'T go down with trim motor, you will have to crack fittings and bleed down again at which point I would say you have trash in a check valve....<br />Good luck!
