joyceenglish
- Jun 24, 2003
- 2
1997 Mercruiser 5.7L V-8 I/O 210hp Thunderbolt V-Ignition System<br />Desperate!! Small area with limited boat mechanics who know what they are doing.<br /><br />Our boat runs great for about 45 minutes to an hour and then it starts hesitating and missing. You can let it cool off for a while and it will run great for another 45 minutes or so. This is not constant running. I am talking about with stopping to put kids on and off tubes. We have changed the plugs and put in a new tank of fuel. After doing this, with just myself in the boat and not pulling anyone, I ran the boat nearly non-stop for over 30 minutes at various speeds. I would stop for a minute or two and recrank it. It ran perfectly. Today we took it back out, and after about an hour, it started missing again.<br /><br />When it starts this missing, it only misses when the engine is underway and pulling a load. If you stop and shift into neutral, it won't miss a lick. Any help would be appreciated. Our next thought would be new plug wires. Also but maybe totally un-related is that it is difficult to start if it sits for any amount of time. We had new distributor cap and coil wire put on at the end of last season. <br />If we take it to the only reliable service center around here, they will put it in the water for a few minutes and say that it runs great. <br />Is there any place on line that I can see a diagram of marked parts on the engine so I can no where to check. I have small amount of knowledge about engines, but can probably figure it out with a little help. Also, is it damaging to the boat to continue to run the boat in this condition? <br />E-mail if necessary to jenglish8577@yahoo.com
