Howdy
Don't know which cool fuel you will be using so this is the basics. The VST supplies high pressure fuel to the fuel rail. The fuel which is not used is returned back to the VST. There are also other methods but as before this is the basic
The first Gen cool fuel uses two regulators, one on the fuel rail and one on the cool fuel module. High pressure fuel is supplied to the fuel rail and the fuel which is not used is returned back to the fuel filter.
Remove the fuel return line going into the VST off the fuel rail and plug.
Remove VST and fuel lines coming from fuel pump.
Under the front of the fuel rail is a regulator which has a vacuum line going from the Reg to the intake. Remove the end from the vacuum hose from the intake.
Install the cool fuel module and route lines to the fuel rail inlet.
Route new vacuum line from cool fuel Reg to Tee fitting under Plenum.
Connect upper Reg vacuum line to Tee
Install new vacuum line from remaining connection on Tee to intake vacuum port
Route new fuel line from cool fuel Reg return port to second inlet port on fuel filter.
Add new fuel line from mechanical fuel pump to cool fuel inlet port
Note parts in link below will be needed
Item 8 - 861267A1 COOLER KIT, Fuel
Item 26 - 32-861569A2 LINE ASSEMBLY Fuel
Item 27 - 25-805063 O-RING (.301 x .070) 2 each
Item 28 - 25-805970 O-RING
http://www.mercruiserparts.com/bam/subassembly/31904/2690/100
If mechanical fuel pump is also remove, run new fuel line from filter outlet to cool fuel
