Mercrusier Smartcraft
Status
Not open for further replies.
Trent
Anybody running this system. I would like to know of any problems you have had? Pro's and Con's.<br /><br />Iv not worked on this system at all. Guess its pretty good????
Walter
Re: Mercrusier Smartcraft
Trent...<br /><br />What is this system you're talking about? A new outdrive set up? If so, I'm not at all familiar with it... Enlighten me...<br /><br />Thanks...<br /><br />Walt
Trent
Its like a outboard in alot of ways....<br /><br />System utilizes a network of sensors and actuators to monitor and protect engine from low oil pressure, temp, over-speed, and low cooling water pressure, and also has a rev limiter if problems occur.<br /><br />Its installed on the new 4.3MPI, 5.0 MPI, 350MAG/MPI, 6.2MPI, 496MPI Sterndrive and Inboard engines.<br /><br />E-mail me your address and I will have some info sent to you if you want. Trentcr@hotmail.com
Walter
It's a done deal. Thank you!<br /><br />Walt
flashback
I don,t know about this Trent.. Been my experience, that the less you need to depend on electronics, the better, especially around water and salt.. yeah, I guess you could argue that the space shuttle is totally electronic, but the systems are very redundant..just a thought...http://www.livorsi.com/smartcov.htm
Trent
Flashback...I agree <br /><br />I like all those pretty gages. Makes the dash look great! :) <br /><br />Just trying to learn somthing about these new ones. Thanks for the link.
Status
