Ok, just started to bring back a 1994 Mercuiser 3.0L. I tried to start it for the first time yesterday and it took a while to get it to start. I got it to run for only about 5 seconds each time. So I took off the distributor cap and took some 400 grit sand paper to the points but that didn?t seem to help. I know I need to do a complete tune up and I will, my question I know if the points are corroded BAD they will make it hard to start or not start at all. My question will bad points allow it to start and run for about 5 seconds and then shut down? When I do get it started I give it more gas and that doesn?t seem to help at all. A little info on the boat it has been sitting and has not been run since maybe march of 2011 thats as far as I know. I do know I am getting gas because I can see it squirting in the carb, when I move the throttle. I suspect I have some bad gas? Thoughts????
