Mercuiser 5.7 LX
Searayjoey
question the engine was hydrolocked due to exhaust failure now on start up you hear a compression his like a blown spark plug for a couple of cranks on start up . Engine runs fine . Just can’t figure where the noise is coming from .. any ideas?
Searayjoey
Mercuiser compressed air noise
5.7lx engine I noticed a compressed air noise on start up can’t find leak . New plugs new manifold gaskets. Engine runs fine .no noise after initial start?
thumpar
Maybe the air around the choke. Hard to understand sounds without hearing them.
GA_Boater
Was the noise there before the plugs and manifold gaskets? Has any other work been done lately?
welcome aboard.
Please at a minimum provide year, engine size, type of induction, etc. if you have it, also provide the serial number.
GA_Boater
Answered my own question. Joey - Starting a new thread left out some key information.
Both threads are now merged.
thumpar
Well that info changes things. Compression check might turn up something. If nothing obvious there do a leakdown test.
