Hello everyone, I’ve been reading posts on this forum for some time (excellent resource!) but this is my first post. I live in a small community near Vancouver BC and recently acquired a used 15’ closed bow runabout (in the process of fixing it up) that came with a mercury 850 “thunderbolt” outboard. It runs well, needs the manual choke now that it’s a bit cool out though. Sadly the remote activated choke no longer works, it just makes noise. I’ve had the boat out on the water after getting it running with muffs in the driveway and it goes like stink! That motor is a screamer!
Also, I have not been able to locate a digital service manual for it, so if you have one and would be willing to share, that would be truly amazing and so very helpful.
However I have a problem: there is a grinding sound a very rough clunk when it shifts from neutral into gear. I think the idle might be a bit high which is causing the issue. I checked the throttle linkage and the timing assembly (I’m sorry if the term is incorrect) to see if there is any adjustment left in the stops, but it is as low as is allowed (from what I can gather). Once in gear, no other issues, smooth and consistent. I changed the oil in the bottom end and there was no metal shavings or evidence of damage.
Is it possible it it could be caused by the idle being too high? This can be adjusted on the two carburetors. I have been reluctant to mess with them as it runs well, just idles a bit high.
However, I’m new to 2 stroke outboards. I have a fair amount of experience wrenching on snowmobiles, atvs and vehicles though.
Thanks everyone!
Thanks everyone!
