bwguardian
- Jul 19, 2016
- 31
I recently bought two outboards to get back on the water. The first one is a 1999 Mercury 115 and the second one is a 1994 Mariner Tracker 115. Both of these are fresh water motors and in good condition physically. The Mercury has a dead hole in cylinder number 4 and the Mariner is supposed to have good compression on all cylinders...I will know shortly. I want to swap the power heads to get back on the water and noticed the ignition parts are some what different. I would like to leave the flywheel, stator, etc. intact on the Mariner and put it on the Mercury mid section with all the ignition parts from the Mercury. I noticed today that the Mariner has a black stator and the Mercury has a red stator and wondering if they are compatible. I can pull the flywheels and change those over to as I will have to any way given the overall goal will be to rebuild the power head off the Mercury but I would like to get up and running with minimal work to change everything over. So will the Mariner flywheel, stator, and trigger assembly work with the coil packs (CDI units) etc. on the Mercury?
I will also be looking for torque specs on the power plant relative to the internals...
