[u]History:[/u] My boat was out the water for a couple of months. I replaced the control cables as well as the oil pressure switch. Also overhauled the control boxes (quicksilver). The oil pressure alarm continually sounds as soon as the ignition is switched on.
Problem:
One engine, since then , is running rough and delivers no contribution to propulsion. I replaced all the plugs to ensure firing on all cylinders - after the prolonged inaction. Makes no difference however. The engine idles okay although it will emit a hiccough every now and then... Open throttle fails to produce the required revs.
Suggestions please.
Problem:
Suggestions please.
