I have a middle 199X mercury 100. I had not used it for while when I took it out for a spin. Seemed to be running fine when it shut off (sort of like overheating). Restarted fine but when I returned I heard too loud of a knock.<br /><br />The compression in all 4 cyl.is 150. It starts easy. At idle it stumples badly every few seconds putting out a lot smoke. Over 1500 RPM it runs OK but with the knock. <br /><br />Is this the rods, reeds, or could a carb problem cause it. Guess which answer I want?<br /><br />Thanks for the help.
