Mercury 110 -9.8HP, question about fitting
gregharvey
My motor will crank with the choke pulled out, but when I push in the choke, it stalls. The bulb remains firm and I have replaced the diaphram and impellar.<br /><br />I discovered a cracked hose which I assume is an oil/lubricant line. It runs from the bottom of where the carberator is to the pistons.<br /><br />In the process of removing this hose, I broke the fitting the hose slides on to (on the piston side). This fitting (or *** as I call it) has a round, brass connector which appears to screw into the Block.<br /><br />I need to know if the fitting is available and whether or not I will be able to screw it back into the block.<br /><br />sure appreciate any help on this, greg
