Mercury 110 hp Fire
rrwoody
After tilting motor to change a damaged prop, the engine caught fire when the motor was restarted.<br />The small fire was quickly extinguished. Is this a direct result from tilting the engine?
steelespike
Re: Mercury 110 hp Fire
Probably a little gas leaked out of the carb(s)<br />while it was tilted.Unplug the gasline and it will reduce that problem some.
Hooty
I'd be curious about where the spark came from that set it off. Sparkplug wire? <br /><br />c/6<br /><br />Hooty
D
DJ
Guest
Hooty,<br /><br />I agree. There is something amiss that created the spark, or plenty of concentrated heat.
