mercury 115 hp
Johnson110
Engine leaks 2 stroke oil down exhaust housing, found that the nuts that bolt the power head to the exhaust housing were not very tight this is the side that I saw oil leaking down. Can loose power head bolts cause oil to leak down? Thanks for any replies!
roscoe
Unburned 2 stroke oil goes out with the exhaust. Builds up in the leg and eventually runs out the bottom. Normal.
